Strokermjcomanche Posted July 8, 2015 Posted July 8, 2015 Yes , the door lock cylinder hole will be smaller on the 95 doors vs the 86 doors . You can either file the hole slightly to fit the older locks or use the 95 cylinder with the newer style key .
86manche207 Posted July 8, 2015 Author Posted July 8, 2015 Yes , the door lock cylinder hole will be smaller on the 95 doors vs the 86 doors . You can either file the hole slightly to fit the older locks or use the 95 cylinder with the newer style key . okay sweet. The 95 doors come with the keys thanks for the help
