wheel pattern
The same bolt pattern is also used by a tremendous number of Ford vehicles and many Chrysler vehicles, as well as virtually all AMC vehicles. If you're considering factory rims from other brands, however, be advised that the Jeep rims use a slightly smaller center hole than many and some other brands of rims won't seat because the center hole doesn't fit around the hub ring.
Also be aware of backspacing, which is the distance from the mounting surface IN (toward the vehicle centerline) to the inner edge of the rim. The factory backspacing is 5-1/4". There are no known rims, aftermarket or other brands of factory rims, with that much backspacing.
Be careful choosing rims. The bolt pattern isn't the only thing you need to match.
5 ON 4.5
almost all new jeeps have that except the jk , cj , fsj and a few others I'm sure
The newest Jeeps have gone away from 5 on 4.5. The WJ is 5 on 5, IIRC, and I think the new Patriot is the same.
