Please HELP!! No power to fuel pump
Any help greatly appreciated. Was driving my MJ, parked for 5 minutes. Started up ran for 3-5 seconds and died. Replaced fuel pump and relay. Still no power to fuel pump. My steering column is old and worn out 310k now going to put in my new used steering column tonight. Any thought???
New fuel pump, filter, regulator and my fuel pressure goes to 45 psi at the start then slowly drops to 20-25 psi. Won't hardley idle. Exhaust does not smell rich of fuel so I don't believe I have a stuck open injector but anything is possible I guess.... Any help appreciated
I would also strongly suggest checking the ballast resistor on the driver side engine compartment by the air box. If these wires are bad or the resistor is bad then there will be minimal power or no power going to the pump.
Another ground would be the engine dipstick ground. Make sure that stud is tight in the block and CLEAN...
Your new regualtor is most likely working correctly but if you have a vacuum leak then that will cause the WRONG fuel prssure to be in the fuel rail. Check various hoses under the hood for any cracked/missing vacuum hoses.
