DAM_MJ88
Everything posted by DAM_MJ88
  1. New fuel pump, filter, regulator and my fuel pressure goes to 45 psi at the start then slowly drops to 20-25 psi. Won't hardley idle. Exhaust does not smell rich of fuel so I don't believe I have a stuck open injector but anything is possible I guess.... Any help appreciated
  2. 88 4.0l...doesn't matter but its not a stock engine... lwb ax15 np231 I forgot about that ground at the taillight! I'll check that tonight. Thank you
  3. Any help greatly appreciated. Was driving my MJ, parked for 5 minutes. Started up ran for 3-5 seconds and died. Replaced fuel pump and relay. Still no power to fuel pump. My steering column is old and worn out 310k now going to put in my new used steering column tonight. Any thought???
  4. Ah i knew this was out there somewhere! Thank you very much :bowdown: :bowdown:
  5. My MJ was torn down to cab/frame and cleaned. All grounds have been cleaned and reinstalled. I pulled most of the wiring harness, cleaned and installed with new grease. All light bulbs work and i have turned the bulbs every way they can go. SO far nothing helps!? All the bulbs are new as well. What bulbs should be in the turn signals?? Either way Thanks for the help. I just have to keep digging. O ya about to install my lift! :banana: Can anyone point me in the right direction to find the forum on getting rid of that load level/brake bias thingy on my bed, I have a 44 out of an 87 XJ so it has drums and i just want to get rid of that thing.
  6. First off I'm new to the forum...so Hello Fellow MJ junkies. :rock on: I have an 88 MJ. Ive had it for a while and i'll post its story and pics one day soon. But i need help cause it's my daily jeep now! Issue 1: all the lights work normal except the Driver side brake light, it does not come on when applying brakes. Top light comes on when i use the turn signal but no brake light. Then when i turn on the running lights, all the running lights come on but the driver side middle light(brake light) stays on like you have the brakes applyed!? Its really frustrating! :fs1: Issue 2: Why do my turn signal indicators in the gauge cluster come on and stay on when i turn the running lights on????Has had this issue since the day i got it! :fs2: dang gremlins! If any one could point me in the right direction that would be amazing! O ya, all the light bulbs are new. Thank you
