DirtyComanche Posted February 26, 2018 Share Posted February 26, 2018 34 minutes ago, Swampy said: I can't find info anywhere on replacing an external slave. I orginally bout a pre-bleed system which was fine but I blew out the slave. I ordered just the slave to replace it and I can't get the old one off. I can't get the roll pin out. I tried using a nail of the same size and no dice, but the nail is stuck in the hole of the roll pin now though There's roll pin punches for driving out roll pins. They're not pointed so they don't expand the pin. Some may have a tiny nub in the middle like a transfer punch to help keep it centered though. Also using something like Knipex plierwrenches often works well for getting a protruding roll pin to start moving as you can get a lot of force on them. Link to comment Share on other sites More sharing options...
Virginia Posted February 26, 2018 Share Posted February 26, 2018 On 7/21/2017 at 9:21 AM, Gene said: Hope it turns out well! Gene It did! Link to comment Share on other sites More sharing options...
