MPI and TBI are completely different. I just done this swap with a 91 YJ MPI into my TBI and lets just say it can get very very touchy. The Big plug on the firewall doesnt match most of the wires so you have to pull the metal tabs out without destroying them and move them so they line up in the right spot so the fuse panel and interior equipment will work. ALso the MPI has so many extra wires you can cut out. Can be very tedious but i love it now plus the my MPG is better. If someone does this i can give a few pointers on it because there are no writeups i could find for it. Good luck selling this is a worthwhile swap for those 4 banger lovers like me.
Cole
Hello Gavin here
I am trying to rewire a 93 2.5 mpfi with all the harness down to battery clamps   in to a 89 comanche 2.5 tbi   the engine is in
not sure about the fuel pump issues? What kind of pump do I need to put in? Do I need to change my tank?
any help would be Happily taken
thanks
Gavin here again
Also any other information on the Vacuum lines
Mostly any information on rewiring the new harness into the old or is it vice-versa
I do believe it won't be hard but a time and patience job And Help From Good People
Thanks again all out there helping this Newbie
I did look at the charts
But what if one does not have the donor plugs for under the dash.
Should i try to get one?
Also how or what do i need under the hood for the plug that goes into the fuse box
i sort of understand the pulling of pins and moving them
any help would be nice
i look under the hood and am just over whelmed
Do you have a donor harness?
You should be able to swap in an XJ or MJ MPI harness then wire it to the rear harness with the info in the link i posted and be good to go.
I have 91 MJ engine and dash harnesses spliced into my 89 rear harness running 95 YJ engine management on my 89 block and head.
I have the computer the fuse box and battery clamps under the hood
i have nothing for in the cab
the write up shows for under the dash
correct
nothing about under the hood
rear harness is where
also what does HO era mean
also the Renix era confuses me
TBI    Renix
MPFI   non-Renix ??
Sorry for all the questions
posting picture ...How
Renix is what you have,HO is basically what your swapping in.
The write up is for 4.0l swaps but the info is the same.
What engine harness do you have? What is it out of?
The harness was attached to the engine I was told it came out of a 93 Cherokee Rwd with only 38000 km on it
the 5 speed transmission was attached as well
So your trying to hook the engine harness to the connector on the firewall,your going to need the pin outs for your truck and the XJ harness then you can see what pins needs moved.
When i did mine i took the entire engine and under dash harness from the donor rig then all i had to do was tie it into the rear harness connectors which are in the driver side kick panel.
I wish it was all there. Sounds easier to rig up
So the XJ harness is the one for under the dash
as in the black and grey one
or the big one under the hood
How can I post pictures
You have too host the pics somewhere,i use photobucket.
Once you do that you can post the img code here and the pic will display.
so would I be able to go and get any 93 mpfi under dash harness and do what your diagrams say
basically plug the 93  main harness  into the wall under the hood  and re wire under the dash
and then just  get rid of old 89 tbi harness
91-93 MJ or XJ should work,the dash harness changed a little in 94.
The dash harness will go from the firewall plug to the rear harness plug in the kick panel,if you get the dash harness that matches your engine harness you should be able to splice in the rear harness and everything should work.
My 91 harness plugged right into the column and everything else under the dash.
