Cluster Swap Clarification
Doesn't have to be '87 - '90. The older ones ('84 - '86) will also work if you change the speedometer cable. With the older ones, you MUST get one from a vehicle with the same number of cylinders. The older ones had no calibration potentiometer. The newer style have a potentiometer that allows calibrating for 4-cylinder or 6-cylinder.
