90 MJ 2.5 and 4x4 swap/upgrade
I've read through several different 2.5-4.0 swap threads as well as the 2wd to 4wd threads but I still need some clarification.  I have a 90 2wd (Renix) 2.5 Comanche that has a beautiful interior and rust free exterior but it's underpowered.  I've found a 91 MJ 4.0 4x4 that is rusted to all get out but I can pick it up at a fair price.  My original plan was to pick up a 88-90 Renix Cherokee and do a complete swap Renix to Renix, which should be plug and play and make it easy on myself but I ran across the 91 MJ locally and I'm curious if I could just do a complete cross over swap Renix to HO if I used everything off of the 91.  In short, my question is for the guys who have done this swap before would it be wiser to stick with the 88-90 (Renix to Renix) swap or if I use everything from the 91 will the upgrade be just as easy going from the Renix to the HO.  Thoughts.........
You can remove the 91 dash harness and install it in your pristine dash. You will need to swap over the HO cluster as well.
I think you would be wise to go with the HO swap, especially with a complete, correct, donor sitting right there. You should have little to no fabrication and everything should fit like a glove. I believe using a Renix donor would require about the same amount of work.
