shipp_m Posted May 15, 2015 Share Posted May 15, 2015 Just looking at getting a Jeep commander for the fiance and kids. any thoughts on this good or bad? Is it a good price? http://www.ewayautogroup.com/2006-Jeep-Commander/Used-SportUtility/Carrollton-TX/5768832/Details.aspx Link to comment Share on other sites More sharing options...
jpdriver1 Posted May 15, 2015 Share Posted May 15, 2015 we've got the hemi in a durango with the 5 spd a/t, very happy with it that is a good looking vehicle Link to comment Share on other sites More sharing options...
dasbulliwagen Posted May 15, 2015 Share Posted May 15, 2015 They are an uglier heavier version of the Grand Cherokee. But I'm sure you already know that. I'm always leery of vehicles that have that many miles being financed. You never know once you're over 100000 miles what repairs might be needed and having to fix high dollar stuff on top of making payments. Price don't seem bad. If that was on our lot they'd probably be asking closer to $20000 for it. If you think its what you want then go for it. At least it doesn't have the 3.7 in it. Its way too heavy for that motor. It has 2 open recalls. One to reprogram the transfer case and one for the ignition switch that doesnt have parts available yet. It was originally sold out of North Carolina to a private security company. Link to comment Share on other sites More sharing options...
shipp_m Posted May 16, 2015 Author Share Posted May 16, 2015 thanks for the information and replies gents. i believe ill pull the trigger on it. was hoping someone with experience with the vehicle could chime in. thanks again Dasbulliwagen and jpdriver1! Link to comment Share on other sites More sharing options...
Incommando Posted May 16, 2015 Share Posted May 16, 2015 They look good with a small lift and a size or two larger tire Link to comment Share on other sites More sharing options...
Lemmon714 Posted May 17, 2015 Share Posted May 17, 2015 I have a 2007 with the 4.7. The typical troubles to look for are- The drain tubes for the sunroof/ moonroof tend to clog and flood the floor. You may need to clean them out or cut the nipple off the end at the floor board. The remote start takes a toll on the starter. The original starters seem to fail. The starter can be removed from under the vehicle- it is tricky but can be done. The transmission is tough, the valve body will probably crap out between 100,000- 120,000. The shifting pattern is a little funky, it has a slow shift in normal mode, it shifts much better in tow mode. The front calipers tend to seize (per the counter guy at the dealer). Lower control arms are a typical complaint for failing. When the oem rear shocks die, Bilsteins are a better replacement. Headlights provide great lighting on the road. The rear seats need to be folded down if you want cargo room or go shopping. I bought it used in 2011 with 60,000 miles for $14,000. There is a recall for reprogramming the transfer case, most people seem to loose the High/ Low function. It drives comfortable, it has good stopping power. The Heat and A/C work well. Some people have weeping around the crimps on the power steering or transmission lines at the front of the vehicle below the radiator. Would I buy again or buy with the 5.7- yes. Link to comment Share on other sites More sharing options...
