windshield wiper switch
thejum57
Looks like I need a new wiper switch. The wipers work when they want. I replaced the motor...and the bushings a couple of years ago. Still work when they want to. Today I barely got them to work at all. Time to take the plunge. It's for an 86 Comanche Custom. Just the basic signal stalk with the 2 speed wiper switch, with the "single wipe" feature if you twist it backwards. Please only one you know works! I'm at 01030. Thanks!
You know there is the lever, and then the switch itself is a separate piece inside the column.  The lever may very well be the issue, but if it is the switch that is bad, that is a separate part inside the column.
Replacing just the lever is like replacing a manual transmission shift lever, when the transmission has worn out synchronizers.
theres a relay that velcros under the lower dash did you replace that thats usually the problem......if not i got all the part you need and i accept paypal and ship fast email me if you need anything kk02108@gmail.com
Very good points! There are a couple of relays down there, if I take a pic would you be able to point it out? I'd sure rather replace that than the switch. And yes Kkilmer, I bought an arm rest from you...very fast shipping and a nice piece, thanks. If I need anything I'll contact you.
