yxmj Posted May 4, 2015 Share Posted May 4, 2015 1987 MJ 2.5 What is the purpose of this plug that gets plugged into the rear of the power steering pump. Changed out my pump to one that was a direct bolt in ....but did not have a spot for the plug. Truck is running fine so I am just wondering what the plugs purpose was? Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 4, 2015 Share Posted May 4, 2015 On the 2.5's the idle is bumped up a little by a high pressure switch when cranking the steering wheel into the stops. Supposed to keep the engine from stalling out under the power steering pump load. The torque-monster 4.0's do not have this feature. :yes: Some guys use this switch for a poor man's extended idle. Link to comment Share on other sites More sharing options...
87Warrior Posted May 4, 2015 Share Posted May 4, 2015 On my 86 2.5, the sensor is in the high pressure hose. Link to comment Share on other sites More sharing options...
yxmj Posted May 4, 2015 Author Share Posted May 4, 2015 Thanks My 151...... fire breathing cubic inch's of raw AMC power..... has no problem turning the pump......so for now it will get Zip tied out of the way :thumbsup: Link to comment Share on other sites More sharing options...
