I can get the front/rear 4.10's axles from a YJ.
Along with a tight 2.5L/AX-5/231
Can I use this setup with my stock rear driveshaft?
for $200 I can get the drivetrain.
can I use this setup?
still need to shorten rear ds to fit colton
anything can be made to work if you want it bad enough. the axles from a yj would take some work, as the comanche has coils and locating arms, where the yj is leaf sprung. i did this swap on a comanche about ten years ago. i had a two wheel drive long wheelbase with the 2.5. i bought a rusted cherokee for $200, that also had the 2.5. i swapped in the trans and transfer case, along with the vacuum disconnect garbage, the front axle, which had the right gear ratio to match my existing rear end. the front driveshaft from the cherokee was a direct fit, and i had a shop shorten my rear driveshaft. i think i swapped speedo cables, and some other minor stuff. its a lot easier and cheaper to have a donor cherokee..
