mjturtle
    e.corinth, vt
mjturtle's Achievements
  1. JEEP Power Memory (+12v Constant) Pink Ignition (+12v Switched) Violet/White Ground (-) Black Illumination Orange Dimmer Blue/White S p e a k e r s Right Front (+) White Right Front (-) Black Left Front (+) Green Left Front (-) Black/Yellow Right Rear (+) White/Black Right Rear (-) Brown Left Rear (+) Green/White Left Rear (-) Brown/White if not that, try this one P o w e r Memory (+12v Constant) Red/White Ignition (+12v Switched) Red Ground (-) Black or Braided Silver Wire Illumination Orange Dimmer (none) Power Antenna Yellow S p e a k e r s Right Front (+) Violet Right Front (-) Blue/Red Left Front (+) Green Left Front (-) Brown/Red Right Rear (+) Blue/White Right Rear (-) Blue/Red Left Rear (+) Brown/Yellow Left Rear (-) Brown/Red
  2. anything can be made to work if you want it bad enough. the axles from a yj would take some work, as the comanche has coils and locating arms, where the yj is leaf sprung. i did this swap on a comanche about ten years ago. i had a two wheel drive long wheelbase with the 2.5. i bought a rusted cherokee for $200, that also had the 2.5. i swapped in the trans and transfer case, along with the vacuum disconnect garbage, the front axle, which had the right gear ratio to match my existing rear end. the front driveshaft from the cherokee was a direct fit, and i had a shop shorten my rear driveshaft. i think i swapped speedo cables, and some other minor stuff. its a lot easier and cheaper to have a donor cherokee..
