HOrnbrod Posted April 29, 2015 Share Posted April 29, 2015 In my parts manual there is a part mandated for XJs and MJs by a Jeep TSB dated 05-51-92. It calls for the install of a brake pedal return spring, p/n 4720825, SPRING PACKAGE. Below is a pic of the spring kit on the bottom. I do not have this spring on my 91 or in hand and do not know how it's installed. I assume it fits over the booster rod stud on the pedal. Does anyone have this brake pedal spring on your rig? Image Not Found Link to comment Share on other sites More sharing options...
cruiser54 Posted April 30, 2015 Share Posted April 30, 2015 Can't find the whole TSB with the procedure? Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 30, 2015 Author Share Posted April 30, 2015 I found TSB 05-51-92 on a list, but no details for the install. Any ideas? Do you have access to these from your days at the dealership? The below is all I could find: Jeep TSB 05-51-92, Brake Lamps Stuck On/Speed Control Inop - Spring Kit, 4720825 Link to comment Share on other sites More sharing options...
mjeff87 Posted April 30, 2015 Share Posted April 30, 2015 I saw a picture of a pedal assembly on one of the other Jeep sites (JU or similar) that showed that clip installed, but damned if I can remember where it was. The post was about how to disassemble the whole pedal assembly (to put a new pedal on) and showed how to take out the crosspin that the top of the pedal swings on. There's a nut on the end that you unscrew and then the whole pin/bolt thingy slides out....that spring was attached to the pin and it clipped over the flat side of the pedal arm. I'll keep looking for it.....hopefully I'll find it eventually. Jeff Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 30, 2015 Author Share Posted April 30, 2015 Thanks Jeff - that'll help. Link to comment Share on other sites More sharing options...
cruiser54 Posted May 1, 2015 Share Posted May 1, 2015 Waiting for a response from my buddy at the dealer. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 1, 2015 Author Share Posted May 1, 2015 Thanks. I don't have the spring kit in hand yet, but it's on the way from NH. Maybe when I see it up close and personal it will be obvious. Looks like an early HO only brake TSB. Link to comment Share on other sites More sharing options...
cruiser54 Posted May 1, 2015 Share Posted May 1, 2015 Yeah. Those HOs were quite troublesome...... Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 1, 2015 Author Share Posted May 1, 2015 Not for me........... Maybe for you though........... Link to comment Share on other sites More sharing options...
