fuse box diagram
that's what i needed, thanks Don.  my problem is the windshield mister no workee, cannot measure power or ground at the pump connector.  Wipers work normally so i jumped onto the violet/white wire that feeds the pump and the black ground wire and installed  new wires bypassing the C100.  Still no workee.  Will dig into it again tomorrow after it stops raining........
i had no power at the motor.  ran new wiring, turned key on had power, but motor no turn.  Replaced motor from my parts stash.  Works as advertised.  The OEM wiring goes thru the C100 connector on the back of the fuse block and I didn't want to go into that beast again.
Thanks to those who replied, good suggestions all.
