1J7FJ36L7KL618490
GregM
1989 Jeep Comanche
6 cyl
Build Date: 6/89
Mileage: 77,626
Recently purchased from the 2nd owner, who puchased it from a friend of mine.  I bought it because of the low miles and I needed a decent 4WD pickup truck back in Indiana for when I'm back there doing some property maintenance and to run around on the 'Back-40'.
Just completed lots of deferred maintenance: Fluids, Idle Air Control Valve, Neutral Safety Switch, fuel filter, rear wheel cyinders, axle seals, 3rd brake light bulb, reglue mirror, brake hardware, rear wheel bearing, TPS Sensor, water pump, replace missing rim, new Firestone Destination A/T tires, replace missing center caps, etc.  The 1st owner took great care of it, the 2nd owner, not so much.  Interior is still pristine, although it needs a new headliner for the second time.  Passed California SMOG today, has a problem with the front axle nasty noise that we'll work on next.
Silver paint, long bed.  Has been repainted once, but needs another repaint.  Could use a right front fender too. Little rust since it was a California vehicle, but will need some attention if we repaint it.
I'm the current owner.
  • 4 years later...
*X8 Cloth Low-Back Bucket Seats
-SA Charcoal
171 Zone 71-Los Angeles
1AA U.S. Dealer Retail
4AF American Coin Merchandising
4EA Sold Vehicle
5AM Largo Tracking
5KN Metro Cars of Detroit
ADA Light Group
ADB Protection Group
ADH Heavy Duty Electrical Group
ADL Skid Plate Group
AHL Heavy Duty Insulation Group
AHY HEAVY DUTY TRAILER TOW PREP PACKAGE
ALN Body Color Bumper Group
APA Monotone Paint
AWE Night Eagle Package
BA1 100 AMP ALTERNATOR
BCY BATTERY, 58-475 CC
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CAC Low Back Bucket Seats
CDB Reclining Front Seats
CKA Carpets - Floor and Cargo Area
CLA Front Floor Mats
CSR Passenger Assist Handles
CUF Full Length Floor Console
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHA Lock-Up Torque Converter
DHN Command-Trac Part Time 4WD System
DHS Floor Mount Automatic Shift Lever
DJH 230MM Front Axle
DMD 3.55 Rear Axle Ratio
DRK Dana 44/226MM Rear Axle
DSA Anti-Spin Differential Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEC Front Left Side Sliding Window
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GNB Driver Side Illuminated Sun Visor
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
HGA Hood Insulation
JAA Instrument Panel
JAY DO NOT USE - See JP, KA classes
JBD BEZEL-I/PANEL CLUSTER - BRIGHT
JCA 85 MPH Primary Speedometer
JGB Digital Clock
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
JKB MOPAR Hood Lock
K2X STRIPE/BADGE/MOLDING/COLOR
K3D STRIPE/BADGE/MOLDING/COLOR
KKE
LAF Seat Belt Alert-Driver Seat only
LAJ Headlamps On Warning Chimes
LBB Courtesy Lamps
LBC Glove Box Lamp
LBD Ash Tray Lamp
LBE Door Armrest Storage Lamp
LCJ DOME/READING LAMP B-PILLAR
LDH U/Hood, Removable/Rechargeable Lamp
LHD Headlamp Off Time Delay
LMA Halogen Headlamps
LPE Cargo Lamp
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MCA Rear Body Color Applique
MDA Front License Plate Bracket
MFG Body Color Headlamp Bezels
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
MMP MOLDING - DOOR EDGE GUARDS
NAE California Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF5 Fuel Tank - 23 Gallon
NHB Auxiliary Transmission Oil Cooler
NHM Speed Control
NMC Heavy Duty Engine Cooling
PS3 DOVER GREY MET CL CT PRIMARY PAINT - HS3
QS3 DOVER GREY MET C C SECONDARY PAINT - HS3
RAA All Radio Equipped Vehicles
RAB AM/FM Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCE Alcantara Wrap Steering Wheel
SFD Front Extra HD Shock Absorbers
SGD Rear Extra HD Shock Absorbers
SUA Tilt Steering Column
TAA All Tires
TAE MUD && SNOW TREAD
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TRN P225/75R15 OWL Wrangler AT Tires
WJD 15X7.0 Styled Steel Wheels
XBS Pickup Box
XEA Tow Hooks
XEE Fuel Tank Skid Plate Shield
XEF Transfer Case Skid Plate Shield
XEU Front Suspension Skid Plate
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z67 Left Front Spring Group XVI
Z86 Right Front Spring Group XV
Body model JM62
Build Date 5/31/89
  • 1 year later...
