Just replaced Battery Cables because of arching, now, not charging.
This is from mu build thread, thought I would post it here for more exposure. Got the cables replaced. Drove it around last night. Went to Advance Auto to look at some things, got into the Jeep, and it almost didn't want to start. Noticed the headlights getting dimmer, and when I put the brakes on, the dash lights would dim. Got back to the house, shut it off, and it wouldn't start (not enough juice). My question is, with the arching that went on before I changed the wires, what would have normally gone first, the alternator or the battery? In the past when the engine was running, it would run 30-40 mins, and immediately restart no problem. That makes me believe everything was fine before the arching. I'm going to first take the battery out and have it tested, and then the alternator if the battery tests good.
Jerry
Not yet, just brain storming until I get home. Think it's the alternator, as it seems the battery was working until it was discharged. With the engine running, everything should have been bright if the alternator was working.
Jerry
Checked the fusable link, it was fine. Took out the alternator, and had it tested, the internal regular and the bearings were shot got a new one, and will be installing it tomorrow.
Jerry
Did you replace both Positive and Negative cables?
How are your connections at all ends of these cables? Clean & Shiny?
Highly recommend the BWD BH315P and BH315N.  (O'Reilly's is only place around me that can get them.)
These are military style connectors you never dis-connect them from the battery.  Your cables connect separately
(These make all these other things used by most "professional audio shops" look like a joke and at half the price.)
Good cables, good connections, GOOD GROUNDS.
And yes, I've spent the entire day replacing everything except these items, the cheapest parts, and then once I did watch
all my problems completely vanish.
Good Luck!
I replaced both cables. I replaced the alternator as well. When I started the truck, the battery was at 11.8 volts. as it ran, the voltage dropped to 9.4 before it leveled out. After the alternator replacement, before starting, battery was at 12.8 (charged it), with engine running, it was at 14.4/14.5. Charging now!!!
Jerry
