projectMANCHI Posted April 8, 2015 Posted April 8, 2015 I have a 1986 Jeep Comanche 2.5l 4 speed manual. Truck has 109,000 original miles. Runs and drives great, shifts fine through all gears, and comes to a complete stop. Lots of parts put on recently, here is a list -rough country 4.5" lift, with adjustable track bar and quick disconnect sway bar links-31x10.5x15 Mickey Thompson Baja MTZ's with 90% tread all the way around-15x8 cragar soft 8's -12 offset-front diff cover, fluid, gasket-40" lightbar-off-road stinger winch bumper, welded on-9000lb offroad winch(used once)-battery/alternator -water pump/radiator/hoses-plugs/wires-new 2" exhaust fully welded, cherry bomb midway, new header gasket-clutch master cylinder-EGR delete -throttle body gasket-more little things probably forgetting ATMThe main bad things about the truck are-Palm sized dent on drivers side behind the door-interior needs a couple things-top speed is about 70 mph on the highway-scratches along side the bed-could use paint if you really wanted it to look great, but its a jeep so WHO CARES, looks better muddy anyways-few vacuum leaks that need to be patched upThe truck is 100% driveable I drive it DAILY, and take it to some light trails every once in a while. 4 wheel drive works great, (CAD DELETE) this truck will never get stuck, gas mileage is not too bad and it's only about 24 bucks to fill up, really need to come see it to fully appreciate its beauty for its age.4000$ cash, price is negotiable, open to trades for other vehicles(mostly trucks) or motorcycles of equal value. CASH IS KING.If interested please contact me @614-205-1848 THANKS TEXT ME FOR PICS
Archived
