How heavy do you think it is? Do you think  3-4 people could pick it up and load it? I have a deck over trailer ( deck is 3.5' off the ground ). Sorry for all the questions.
Probably weighs 500 to 1,000 pounds. Even at 500 pounds that will require lots of heavy lifting. It would be better to bring some wood to make a temporary ramp and a hand winch to slide it up on to the trailer. Also, a couple friends to help.
This. I have two hand winches and a few boards. You can measure the height of the trailer deck and we can put more boards under the frame of the truck to lift it higher if needed. I have a floor jack and a cherry picker.
Guest
This topic is now closed to further replies.
