Hello all. Recently, my MJ has developed a leak where the fuel line meets the TBI unit. Has anyone replaced these? If so, did you have something made up, or is there a stock replacement? Thanks a bunch!
Mine were replaced before I bought the truck........I've not bothered to seek out new lines.
However, if I needed to-
Any hydraulic shop should be able to set you up.
Or-
You can use regular fuel line and fittings, you are only dealing with 15lbs of pressure.
I'd opt for braided steel for appearance sake.....yeah, it'd cost me $40-50 bucks......but.........
