1991 pioneer front passenger axle
I have a question regarding some pieces of plastic I found inside the 4wd actuator cover?? I think that might be what it's called. I will apologize in advance for not knowing technical names. Last year I moved the fork over inside the cover to engage the front driveshaft all the time. This worked fine and my 4wd worked fine as well. I accidentally left it in 4 wd on hard pavement and made a right turn and I heard a loud pop and there was a bad grinding noise when I put it in 2wd. I had to leave the case in 4wd so there wasn't grinding but the 4wd was not working. When I got home I pulled the cover and the fork was riding in the 2 axles. I move the fork back over and the 4 wd worked again and the noise in 2wd went away. A Little later while in 4wd I heard the pop again and the same thing happened. When I pulled the cover off I found some small pieces of plastic and there was a little play in the passenger side axle and that axle will still not stay engaged. What are these small pieces of plastic and what can I do to fix it. Thanks in advance.
There is a plastic dust shield that should be on the outside of the axle tube
This on is off a ZJ but you get the idea.....could it be this
Maybe it was broken and driven in some how?
Or installed incorrectly?
