CGCWO Posted March 18, 2015 Share Posted March 18, 2015 So I replaced a leaky clutch master cylinder, bled what seemed to be all the air out. Kept going until nothing but clean fluid came from bleeder. Now the pedal will occasionally go to floor with almost no resistance. Checked the reservoir for bubbles, none detectable. No loss of fluid in reservoir since replacing the master cylinder. So I am thinking it has to be air still in the system, what do you guys think? Link to comment Share on other sites More sharing options...
86FUBAR Posted March 19, 2015 Share Posted March 19, 2015 Did you bench bleed the master befor installing it ? Link to comment Share on other sites More sharing options...
CGCWO Posted March 19, 2015 Author Share Posted March 19, 2015 Yep, more and more thought and I believe it could be the additional pressure from the new master cylinder could be collapsing the diaphragm in the slave. Going to try and bleed the entire system again then see what happen. Link to comment Share on other sites More sharing options...
