91Pioneer Posted March 12, 2015 Share Posted March 12, 2015 So I bought a new battery for my MJ, and decided I should remove the battery tray and clean things up... turns out that was a bad idea because 2 of the 3 bolts in the tray broke off. I even sprayed penetrant and left it for a couple hours before trying to loosen them by hand with a breaker bar. So I got to looking at the body-side bolts and it seems they're pressed in from underneath, like massive rivets or something. I'm leaning toward just re-installing with the one good bolt and saying "good enough". One of my T-bolts on the hold-down is also broke off (it was like that when I got the truck). I would feel better if I could ensure the battery won't bump around and short anything. After all it's a brand new battery ;) Your thoughts? Should I try drilling out even one of those "bolts" to get a second bolt installed? p.s. Where can I buy a replacement long T-bolt? Link to comment Share on other sites More sharing options...
wvzj Posted March 12, 2015 Share Posted March 12, 2015 I would try drilling it out and replacing them. Here is a link to some battery parts and the j bolts http://www.jeep4x4center.com/battery-trays-cables-clamps/jeep-cherokee-xj.htm Link to comment Share on other sites More sharing options...
91Pioneer Posted March 12, 2015 Author Share Posted March 12, 2015 I took a closer look at things. Yeah as long as I can drill out one of those broken off "bolts", I'll just JB weld a new bolt in it's place and move on. It would be nice to have things stay in place LOL Link to comment Share on other sites More sharing options...
Eagle Posted March 13, 2015 Share Posted March 13, 2015 I'm leaning toward just re-installing with the one good bolt and saying "good enough". In this case, "good enough" is not good enough. Your thoughts? Should I try drilling out even one of those "bolts" to get a second bolt installed? Yes, definitely. Link to comment Share on other sites More sharing options...
91Pioneer Posted March 14, 2015 Author Share Posted March 14, 2015 I just drilled a new hole beside the broken-off bolt and used a thick self-tapping metal screw in there. It's sturdy as can be now. I'll hit up the junkyard for a T-bolt (no sense in buying new) next time I'm there. My truck starts much better now, what with not needing to boost it every time LOL Link to comment Share on other sites More sharing options...
