tylergrant2011 Posted March 8, 2015 Share Posted March 8, 2015 My fuel pump will cut on when I turn the key but no fuel or pressure coming from the line. Any tips? Link to comment Share on other sites More sharing options...
Dando Posted March 8, 2015 Share Posted March 8, 2015 Clogged fuel filter? Link to comment Share on other sites More sharing options...
tylergrant2011 Posted March 8, 2015 Author Share Posted March 8, 2015 Disconnected the line before it reaches the fuel filter nothing coming out Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 8, 2015 Share Posted March 8, 2015 clogged pick up screen............or.........motor runs but does not pump. Link to comment Share on other sites More sharing options...
tylergrant2011 Posted March 8, 2015 Author Share Posted March 8, 2015 I can hear the fuel gurgling in the tank when I turn the key Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 8, 2015 Share Posted March 8, 2015 Fuel line is rotten and split in two, gas is being pumped back into the tank. Link to comment Share on other sites More sharing options...
tylergrant2011 Posted March 8, 2015 Author Share Posted March 8, 2015 The line in the tank? Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 8, 2015 Share Posted March 8, 2015 You're going to have to take it apart.......no way around it. Link to comment Share on other sites More sharing options...
tylergrant2011 Posted March 8, 2015 Author Share Posted March 8, 2015 How long/difficult of job is this? Link to comment Share on other sites More sharing options...
jimoshel Posted March 8, 2015 Share Posted March 8, 2015 Two hours. . I have replaced the pump without removing the tank. Link to comment Share on other sites More sharing options...
tylergrant2011 Posted March 8, 2015 Author Share Posted March 8, 2015 Did you remove the bed instead? Link to comment Share on other sites More sharing options...
jimoshel Posted March 8, 2015 Share Posted March 8, 2015 No. There is enough room to remove the unit by tilting it. Remove the ring that holds everything. The wires go to a plug that you unplug. Clean the area first so you don't get dirt in the tank. Link to comment Share on other sites More sharing options...
jimoshel Posted March 8, 2015 Share Posted March 8, 2015 Should mention, make sure there is less tan a half a tank of gas or it will spill out when you remove the pump. Link to comment Share on other sites More sharing options...
