For the past few days now my truck has been running pretty normal and good, except when put into reverse. When put into reverse the truck stutters AND stumbles and acts like the engine is surging for fuel. Runs absolutely fine in drive all the way from idle to highway speeds. Trans is full of fluid that looks perfectly fine. Any thoughts?
1990 MJ 4.0 with the aw4 and np231 out of a 95 XJ.
In case there was any interest in this problem, I found my solution. The solution was simply replacing the missing bellhousing bolts. Simple fix.
