Check my work, please!!
Hello all. It's been a bit over a year since I took the plunge into MJ-world, and I THINK I'm about ready to perform a 4x4 conversion on my truck. I would really appreciate it if y'all would lend me a hand by letting me know if I'm forgetting something before I start tearing my truck apart.
So far, I have collected:
A front diff off of a 98 TJ
A rear diff off of a 98 Explorer Limited
AX5 (to replace AX4) off of a 95 YJ
NP231 off of a 88 YJ that was equipped with a 4.2/BA10
Spring perches from Ballistic Fab (keeping it spring under)
Tubular LCA's and new UCA's
Poly leaf spring bushings
Beefy shackles
Front brake lines off of a mid 90's C1500
I know I need driveshafts, a new flange for the 8.8, a new trans mount (mine's hashed), as well as having to cobble together some sort of shifter for the T-case.
What else do you guys think I'll need?
Oh, and I pulled some 4+1 MT springs from a 2wd junkyard MJ.
If I use the MT springs, will adding my stock main leaf into the pack give me more lift, or will it just make the truck ride worse? I have a 3" lift in the front right now. I'm looking for around 2-3" of lift in the back and I figured now would be a good time to knock it out.
You sure your t case and trans will mate?
Actually, I'm not 100% on that. :-/ I know the BA10 had a 21 spline output as does the AX4/5. I got the t-case locally in VERY good shape for 100 (with a free BA10/5 thrown in the mix), so, if it doesn't mate automtically, I won't feel too bad about buying parts for it to make it mate to my AX5.
You will want long shock tabs/mounts/brackets since you are staying spring under to put the shock mounting position relatively close to stock. I was able to modify a set of TJ 8.8 swap shock brackets for my truck. However, RuffStuff has some long curved shock tabs that I think would work perfect (and I would have used if I wasn't in a hurry).
http://www.ruffstuffspecialties.com/catalog/merchant.mvc?Screen=PROD&Store_Code=ruffstuff&Product_Code=R1653&Category_Code=shockbracketstabs
You will also need center pins or rounded off grade 8 bolts (to fit the aftermarket spring plate that is designed for SOA, they all are) for your leaf spring rebuild.
If you use the stock spring plate then you have your shock mount already in the correct location. I think the ford axle is a little narrow you may need wheel spacers.
I tried to go this route with my 8.8 swap. However, I was uncomfortable with the minimal material left on the spring plate after I elongated the holes to fit the much wider Ford tube width.
