ownedueasy Posted January 24, 2015 Posted January 24, 2015 Ok so for the last few months I've been noticing a rattling noise coming from the passenger side door pillar by the windshield. And I can't seem to find it, the trim screws are tight, weather stripping is tight, everything seems to be tight as it should be. Half tempted for the hammer method it's driving me that nuts
Keyav8r Posted January 24, 2015 Posted January 24, 2015 Is it a metal on metal rattle or a plastic on metal rattle? Maybe there's some wiring running through the passenger side B pillar that came loose. Not sure if you can see the bottom end of the B pillar from under the dash. You could possibly use a mirror to look for it and see if there's anything hanging out.
NHMJXJ Posted January 24, 2015 Posted January 24, 2015 Did you get someone to drive while you investigate?
ownedueasy Posted January 25, 2015 Author Posted January 25, 2015 I have investigated while someone drove, it sounds like metal and plastic, maybe metal on metal muffled by plastic. And no wires that I know of they're all tight I removed interior trim and didn't see anything
ownedueasy Posted January 26, 2015 Author Posted January 26, 2015 There's 2 antenna wires ran, it sounds to be up high about at the bend in the door.
