Wrz Posted December 23, 2014 Posted December 23, 2014 in the process of gathering some parts to convert to mj in the spring to obd2, I have access to just about all the other parts, or have time to find them except the pump assembly Has to be for a 91-92 jeep comanche with a lwb Working or non working is fine since i will be sending it out to get refurbished if you have an extra or are willing to part with one shoot me a pm paypal ready
xjrev10 Posted January 17, 2015 Posted January 17, 2015 You're looking for a sending unit actually then. The pumps are readily available.
HOrnbrod Posted January 17, 2015 Posted January 17, 2015 The 91-92 MJ fuel pump sending units were all standardized. LWB, SWB, and tank size do not matter; they all used the same sender. The p/n is 4637184, and it's stamped 52017559. The below is what a NOS unit looks like. Good luck. Probably one of the hardest MJ parts to find..................
