KCsurfer420 Posted December 3, 2014 Posted December 3, 2014 Hey guys I am almost finished working on my 99 swap in my Comanche and I need to get the door wiring squared away. I used a 4 door harness with a 2 door switch and face plate in my 99 doors and I can roll the windows up and down from the drivers side door but the passenger side switch does not work and neither do the locks from either door. I have pulled both of the switches apart out of both doors and neither one of them had any problems with them. I also jumped the door lock wires and still no avail so I am almost certain that the wiring for the rear XJ doors that are non existent are causing the problem because the harness is seeing no switches at those locations.. I need to get a schematic for the 2 door and the 4 door for the power windows and the door locks so that I can chase down the problem and see If I can just connect the wires at the plugs to close the open circuit and get the locks and the passenger side window switch working. Has any one had this issue with there swap? I'm hoping Alexia will chime in as I believe that he may have crossed this bridge already..
shelbyluvv Posted December 4, 2014 Posted December 4, 2014 I pulled a two door harness and it had the wiring for the rear doors also. They were just open connectors. My 97 swap worked fine with the two door switch and the four door wiring though. Recently my passenger switch went south though so I am in the same boat with a dead passenger door but it works from the master.
KCsurfer420 Posted December 4, 2014 Author Posted December 4, 2014 Thanks for the reply, so your locks are dead too even from the ds door? My locks just don't flat work at all. I pulled the wiring out of the ds door b/c the speaker was dead too. I found a broken wire for the speaker but the other wiring looks to be fine. I'll have to grab another switch at the jy this weekend I guess or realy play with a wiring schematic to chase my issue down. The windows roll up from my side just not from the passenger side and the locks are completely dead....
shelbyluvv Posted December 4, 2014 Posted December 4, 2014 My locks and windows work from the master switch on the drivers side. Both sides will work from that swich. The passenger side switch won't do anything now.
KCsurfer420 Posted December 4, 2014 Author Posted December 4, 2014 Then I may have a problem with the lock relay. I need to get my hands on the electoral portion of the 99 fsm so I can start tracing the wires out and testing every thing w the meter.... it may be the lock relay as the fuses are all good.
