92 in J.Y. with trailer hitch
Found a 92 Comanche in a J.Y. today with a frame mounted trailer hitch like I have not seen before.  This hitch was bolted to the bottom of the frame rails like on the WJ.  Not to the bumper mount points like a normal Comanche.  Also the cross tube was rectangular rather than the normal square tubing.  Finally the receiver tube had been welded to the stock MJ bumper where it was normally bolted.
Unable to remove the hitch because the bolts were just spinning (nuts not holding in place in the frame tube.
Any thoughts on how I can get this off with hand tools in the Junk Yard?
I did get a straight tail gate off the truck.  I left a solid one piece rear window and a bench seat in the truck.  Did have a 5 speed attached to the 4.0.  Some Gray interior plastic and B pillar lights were left.  Bed is trash.
Also scored a windshield washer bottle and pump from a 97 Cherokee that will replace the leaking windshield washer on my 91 Comanche
Snag that vin number and post it up if you don't mind.
VIN# 1J7FT26S2NL107544     Year first sold 1991,  Mod year 1992   2 wheel drive 5 speed transmission Dana 44 rear end.  no metric ton - 3 leaf springs plus 1 overload.  Hand brake gone.  4.0 engine and trans still there.
