My tail lights are starting to pull apart and rather than buy a new set(mine are in decently good shape) I would like to see if there is anyway to reseal them. Any input is appreciated!
Are you talking about the red lens is seperating from the back housing? If it's a small spot take a soldering iron and you can run it on the plastic which will melt it slightly and allow you to press them back together. This works better if there's some kind of filler material available like you would use if tig welding to melt onto the soldering iron to fill in the gaps and prevent big holes from opening up.
yes the red lens is starting to separate from the back, last time I looked at it it was about half the lens, so I've been trying not to mess with it much but it bothers me enough to want to fix it
Fix it before it falls all the way apart. They're too expensive to not fix immediately
Looks like I need to go pick up some clear silicone in the next few days... I don't want to buy new tail lights at $100+ for a set
