Pete M Posted September 19, 2014 Share Posted September 19, 2014 I can get it to start by bypassing the starter relay so the battery is good, starter is good and it does run. the dash lights dim when I turn to start. swapping starter relays didn't fix anything. tried bypassing the nss as I had seen online but with no luck. even unplugged the screwy aftermarket radio with no change. is a 96 new enough to have some sort of disabler? it's been sitting a while with no battery in it, but it's not the first time that's happened and it's never done this before. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted September 19, 2014 Share Posted September 19, 2014 I had an ignition switch give me the same problem on my 95 xj drivline that is now in my mj . It's worth the 5minutes to take the column trim off and check to see if the switch / wiring is burnt .Maybe some critter chewed some wiring? Link to comment Share on other sites More sharing options...
Pete M Posted September 19, 2014 Author Share Posted September 19, 2014 :doh: duh. didn't even think of that. If I remember right, I'm checking for power at the yellow wire with the key turned. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted September 19, 2014 Share Posted September 19, 2014 I did mine 8+ years ago and can't recall . Maybe a wiring guru can get a diagram . I can check my Haynes manual but it's not as good as a FSM, PDF or diagram . Let me know and I can get the book when I get home . Link to comment Share on other sites More sharing options...
Pete M Posted September 19, 2014 Author Share Posted September 19, 2014 no need. I'm positive it's yellow because that was the one that was disconnected. :D seems a previous owner installed a new ignition switch and hacked up the harness in the process. the yellow wire simply popped out of a butt connector. good as new(-ish). :thumbsup: Link to comment Share on other sites More sharing options...
