SpaghettiBatman Posted August 14, 2014 Share Posted August 14, 2014 I recently purchased an 86 Comanche, user Shawn's grey one. I need to replace and remove a broken banjo bolt. I'm not entirely sure what size they are. I have done a bit of googling and they seem to be http://www.brakeconnect.com/product/banjo-bolt-38-x-24nf-stainless-steel 3/8 x 24nf. Would like confirmation and if using a torque wrench is necessary. I'm removing the broken bolt with a left hand drill bit and if that doesn't work following up with easy outs. Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 14, 2014 Share Posted August 14, 2014 Yes, the size sounds correct. You know the calipers are only $17 at Advance......? And the bolts should only be about $2 each. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 15, 2014 Share Posted August 15, 2014 Even at the dealership the bolts are only $1.91. But they are not stainless. Who cares.................. Link to comment Share on other sites More sharing options...
SpaghettiBatman Posted August 15, 2014 Author Share Posted August 15, 2014 I didn't plan on buying those exact ones. With a local 4x4 club I get 30% off at lordco. I will probable have to buy calipers as well since those ones have been sitting for a year and ive been told that they soak up water from the oil being hydro absorbent. If they are that cheap then i will pick up a pair and just not even bother with the easy outs and left handed drill bit. Link to comment Share on other sites More sharing options...
xjrev10 Posted September 2, 2014 Share Posted September 2, 2014 Did you end up finding banjo bolts? I was told they where discontinued and not available anymore by the stealer and quadratec. Link to comment Share on other sites More sharing options...
