Hello again, I just finished rebuilding my NP231 Transfer case after a seized front u joint installed by a PO almost completely tore it apart..
But anyway, I got that sorted but when it came to replacing the output seals none of the ones I bought fit!
Are the seals different between the NP231 and the NP231J?
Either way, could someone please give me the part # for the front and rear output seals? I'd really appreciate it! Thanks!
The problem I have had with output shaft seals is that the Spicer catalog show the wrong number for the rear output shaft seal for a 231J. The one it lists is for a 231D for the larger diameter Dodge slip yoke.
Can't remember where we found the correct part number anymore, though, nor what the correct parf number is.
