Trans question
I found a guy that has a ax5 for a 2.5, been told that the 3rd gear grinds a little. How hard would it be to overhaul it???
He has it for $50 OBO , only problem is it's in AZ so shipping is going to run about $85 to get it back to Ohio.
Charles
Are you looking for a replacement for your jeep or a conversion. I have an ax-15 in a 94 cherokee i am parting out and live in indiana and would sell for $75.00. Let me know if your interested
mudrunt has a 4x4 ax-15 out of a 4.0 and I have a 2x4 ax-4 hooked to the 2.5 in the MJ. Any way to fit the ax-15 to the 2.5 using my ax-4 bell and clutch???
Charles
not that I know of, however, I "believe" that you can use the bellhousing from an early 90's dakota, as they had the AX-15 as well.
AA has a kit, if you're loaded....
You can cobble together the same thing with a Dakota bellhousing, a Camaro clutch and a CJ pilot bushing/bearing. There's a huge post over on Pirate that explains it all.
Jeff
