BryceOJ Posted June 29, 2014 Share Posted June 29, 2014 So I have a pretty decent leak coming from one of my transmission lines. The leak is coming from the line that the fluid runs from the transmission to the radiator. It's seems that the bracket that holds the two lines has rubbed and formed a crack on the edge of the line. Like it has dug into it. How should I go about fixing this? The bracket The leaky spot I've looked all online for a replacement line and haven't found anything that looks similar to mine, though I shouldn't go by pictures alone I just have a hard time finding things due to it being for a 4.0 instead of being for my 2.5l. Or it being for a later 2.5L. I don't want to buy a new one and it being the wrong one. The line runs from the left side, in relation from the front of the vehicle, of the transmission straight toward the front and then makes a 90 degree angle across and under the engine and then to the bottom right corner of the radiator. Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 29, 2014 Share Posted June 29, 2014 It's fairly low pressure. Cut the line and splice with fuel hose and two clamps. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 30, 2014 Share Posted June 30, 2014 Rock Auto carries the tranny coolant lines and fittings if you want to replace them and do it right. Pressure Hose 624301Return Hose 624300Metal tube 624334Fittings at Tranny 800714 Link to comment Share on other sites More sharing options...
