Jeep Driver Posted June 27, 2014 Share Posted June 27, 2014 Which hoses are you guy using? I'm looking at the 2004 Explorer as being the most likely. Thanks Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 28, 2014 Share Posted June 28, 2014 The Teraflex hoses and hardware will work for the Ford calipers. That's what I used. http://www.quadratec.com/products/12700_405.htm Link to comment Share on other sites More sharing options...
Blue XJ Posted June 28, 2014 Share Posted June 28, 2014 What disc conversion are you using? I used ZJ hoses and parking brake cables on mine. Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 28, 2014 Author Share Posted June 28, 2014 What disc conversion are you using? I used ZJ hoses and parking brake cables on mine. Aren't the hoses a little short? I'm going to the front of the axle housing. Are the cables long? I was going to grab the Liberty cables but they go all the way to the console.........like 83" or something like that...... 8.25 with Liberty hardware. Link to comment Share on other sites More sharing options...
Timeless Posted June 28, 2014 Share Posted June 28, 2014 I used ZJ hoses to the calipers. All disc brake parts were from a 96 ZJ. Works just fine. Link to comment Share on other sites More sharing options...
Blue XJ Posted June 28, 2014 Share Posted June 28, 2014 I used the ZJ hoses but I made new hardlines from the splitter blockthing too. The old lines weren't looking all that good and I figured it was a good time to spend $15 to replace them. Disregard my comment about the parking brake. I am using ZJ cables, but I also hav a console/parking brake handle from an XJ installed. So my lengths would be a lot different then a normal MJ's. Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 28, 2014 Author Share Posted June 28, 2014 The Teraflex hoses and hardware will work for the Ford calipers. That's what I used. http://www.quadratec.com/products/12700_405.htm I just picked up a pair of 2000 S10 hoses at NAPA, identical to the ones you posted here. Also, 2000+ Chevy 1500 look viable but they only had one side. $30 Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 28, 2014 Author Share Posted June 28, 2014 Called Morris 4x4 today.......Oreillys.......Advance......Giles.......Spoke to others in the past....... Shrug........ Thats what I get. No imagination whatsoever. Finally I went in to NAPA and told the counter guy I wanted to look in the back and go through boxes till I found what I wanted.....took me less that 5 minutes. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 28, 2014 Share Posted June 28, 2014 The Teraflex hoses and hardware will work for the Ford calipers. That's what I used. http://www.quadratec.com/products/12700_405.htm I just picked up a pair of 2000 S10 hoses at NAPA, identical to the ones you posted here. Also, 2000+ Chevy 1500 look viable but they only had one side. $30 About what I paid too about four years ago - from Ebay. Link to comment Share on other sites More sharing options...
