Wiring Waggy Lights On Xj.
Does anyone know how to wire the Cherokee XJ tail lights (the ones with separate brake and turn signal bulbs) to be like the Wagoneer XJ tail lights (combined brake and turn signals)?  I know that there's a wiring diagram to mate the XJ dash harness with MJ tail light/fuel pump harness.  I was successful with that when I did my swap on my MJ.  Was wondering if the same can be done for the XJ's tail light harness.
Edit: This is the write up I'm referring to. http://comancheclub.com/topic/18588-xj-dash-harness-to-rear-mj-harness-wiring-guides/
Is it as simple as connecting pin #3 of the C118 connector to pin #5 of the C119 connector to get the tail lights to function like the Waggy lights?
"# Pin 3 on XJ C118 connects to pin 5 on XJ C119. This will provide proper wiring for the brake lights."
I've read a few places in the interwebs about people using a trailer wiring harness to use single light housings in the rear of their XJs. I've thought about doing similar if I'd ever go HO in my '88. Maybe something like that?  :dunno:
Yea, I read about that too or just finding a Waggy tail light harness, as those are Plug & Play.  But, I've been looking at my XJ and remembered that I have a factory installed Reese trailer wire convertor.  I will just use that I guess.  I've got the JCR steel tail light boxes recently and am doing LED STT lights.
