How Good/bad Is The Np 207?
The chain is wider than the 231's,but the planetary gears have less contact area in relation to each other. I'd say, strength-wise, it's a toss up, though the 231 does have a much better aftermarket.
Thanks so not worth swapping for a 231?
Depends... what are your plans for your truck?  If it's pulling DD/utility/light wheeling duties, I'd say keep it. If you plan on going hardcore with it or doing an engine/tranny swap, get a 231.
