Help with a couple of questions
I am in the process of converting my 88 MJ from a manual (BA10/5) to an automatic trans (AW4). I removed all the parts from a donor 89 XJ that I owned. My questions are the following:
1. I am replacing the wiring harness to accommodate the TCM. Do I have to install the ECM from the donor or can I use the one currently in my MJ?
2. If I have to replace the ECM, the donor vehicle had ABS, will that affect my swap at all?
Any help is certainly appreciated.
Thanks for the info. I salvaged everything I thought I would need off the XJ including the throttle body, trans crossmember and flexplate.
nice, I'm planning a swap from the BA10 to an AW4 myself soon, but i plan on using an http://www.awshifting.com style shift kit, cause I'm not sure i want to deal with all the wiring stuff... i might later on if it gets annoying.
you know, I was thinking, an AW4 swap with a column shifter and that 4 speed arcade style shifter in the center console would be pretty freaking sweet.
I am going with the stock shifter for now. I also salvaged the buckets and console from my XJ, I'm going to see how they fit up. The BA10/5 will be available soon, I want nothing more to do with it once its out.
