1987Comanche Posted April 30, 2014 Share Posted April 30, 2014 I'm working on Georgia's 4WD conversion and found that, in 2WD form, her springs are P/N 52001118, Code FJ (still has a tag on one spring). These are listed in the parts manual as #780. The donor '96 Sport had P/N 52001117, Code FH, listed as #733. I had expected the donor 4WD to have slightly beefier springs than Georgia but, from what I can tell, the MJ springs are the beefier ones. I'm basing this on the sequential listing of P/Ns (parts manual goes from LD, through SD, and to HD springs). I've looked around but haven't found a definite answer as to what the 733 or 780 means. My best guess is that it's the spring rate expressed in lbs/in. I'm leaning towards reinstalling her original springs (52001118) as they should have a higher spring rate. Any info out there I'm missing? Link to comment Share on other sites More sharing options...
Pete M Posted April 30, 2014 Share Posted April 30, 2014 XJ packs are very different than MJ packs. shorter and much less arch. you'll need to use the MJ main and overload, but the ones in the middle can be mixed and matched to get the height you want. I'm a fan of 2wd MJ packs with an extra main (with the eyes cut off) from a donor pack thrown in as a new second. Link to comment Share on other sites More sharing options...
1987Comanche Posted May 1, 2014 Author Share Posted May 1, 2014 Should have specified the front coil springs, not leaf springs. Still it answers my question...I'll use the coils that came with the MJ. Link to comment Share on other sites More sharing options...
Pete M Posted May 1, 2014 Share Posted May 1, 2014 oh, then that's different. use the 4wd coils. 2wd ones are a bit shorter. :thumbsup: Link to comment Share on other sites More sharing options...
