jahiatt Posted April 16, 2014 Share Posted April 16, 2014 My horn doesn't blow. Jump wire it and both will sound off. All the fuses are new in the fuse block. Ive cleaned the metal disc in the wheel. ' When I press the hown disc, I can hear a slight clicking. SOMEONE PLEASE TELL ME WHERE THE HORN RELAY IS LOCATED. EVERY MANUAL I HAVE SAYS NOTHING ON RELAYS OR THE HORN. MAY BE THE RELAY, MAY NOT, I JUSTT WANNA KNOW WHERE ITS LOCATED. 1986 COMANCHE X 2.8 5 SPEED Link to comment Share on other sites More sharing options...
yxmj Posted April 16, 2014 Share Posted April 16, 2014 Trace your wires back from the horn. On your year I think the relay has a silver metal case with 2 mounting screws and 3 terminals. Trace the wire my best guess is on the drivers side fender or if not under the dash. Link to comment Share on other sites More sharing options...
AeroNautical Posted April 16, 2014 Share Posted April 16, 2014 Mine just went bad, it would click very rapidly as I drove, but the horn wouldn't sound. Mine was a white 3 prong, located under the dash, just behind the e-brake cable. It'll have two plastic tabs on each side of the relay locking it into the connector. Mine is an 88 4.0, so I'm willing to bet it's different, but atleast you can check to make sure. Link to comment Share on other sites More sharing options...
jahiatt Posted April 17, 2014 Author Share Posted April 17, 2014 Thanks, it was the white 3 prong under the dash next to brake cable. It wasn't bad so I removed the horn and used sandpaper for a better ground. Horn works now. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 17, 2014 Share Posted April 17, 2014 Thanks, it was the white 3 prong under the dash next to brake cable. It wasn't bad so I removed the horn and used sandpaper for a better ground. Horn works now. R*C*B*R*C.. Refresh Connections Before Replacing Components. Nice job. Link to comment Share on other sites More sharing options...
