Bornindesert Posted April 5, 2014 Posted April 5, 2014 Just picked up a Dakota Bell Housing from Onlyinajeep726 and gathering info on the AX15 upgrade for my Red Devil Comanche project. Assuming I find a 1995 XJ 4.0 4x4 5spd, does anyone know what parts I need for the Clutch? I know I need a Renix flywheel, do I re-use the 12" 2.5L flywheel? It has a pilot bearing, not bushing, assuming that gets pressed out and replaced with a new bushing? The 2.5L 14 tooth 9" clutch plate has to go, what do I use for the AX15? Same questing for the pressure plate.
onlyinajeep726 Posted April 5, 2014 Posted April 5, 2014 If you're lucky enough to find an AX15 from a Dakota, you can use a clutch kit designed for it and a Jeep 231/242 will bolt to it (if you find a 4WD version, obviously). Otherwise I just discovered this: http://www.naxja.org/forum/showpost.php?p=245778235&postcount=17 May be of some help.
