ggcnash Posted March 23, 2014 Posted March 23, 2014 Hi guys need some help my aw4 in my 91 mj just took a nap yesterday it was out of a 95 xj simple plug and play. Well i called around trying to locate a new one my buddy has a 96 obd2 he just had rebuilt but the cherokee got wrecked before he could install it. He's gonna give it to me for a really good price I know this has been done before from searching the Internet, but it's pretty vague was wondering if any of you guys have done this before and possibly some details on how to pull it off any help would be greatly appreciated
JeepcoMJ Posted March 23, 2014 Posted March 23, 2014 Change neutral safety switch to early model. Should be able to direct splice the other connector by simply trailing what goes where. None of the functions changed, so your TCM will still control it.
ggcnash Posted March 23, 2014 Author Posted March 23, 2014 Change neutral safety switch to early model. Should be able to direct splice the other connector by simply trailing what goes where. None of the functions changed, so your TCM will still control it. He says the harness has 7 wires and I believe mine has 5 I might be mistaken though? Oh well I'm gonna get it he just put 1k in it at a shop and he is gonna let me have it for 400 so I guess I'll just bug you with pm's when I get it lol thx
JeepcoMJ Posted March 24, 2014 Posted March 24, 2014 The wires you will not use are going to be painfully obvious. They are for two green sensors that you can simply ignore.
ggcnash Posted March 24, 2014 Author Posted March 24, 2014 The wires you will not use are going to be painfully obvious. They are for two green sensors that you can simply ignore. Thanks a lot man hopefully it's that easy if not hope your available!
