led_balloon Posted April 25, 2007 Posted April 25, 2007 there is rust under both of my doors on the rocker panels and i want to replace them is it an easy fix of should i bring it to a bodyshop thanks for the advice LEDZEP
JeepcoMJ Posted April 25, 2007 Posted April 25, 2007 EZ fix. decide if you want it to look stock or look beefy...if stock, you can order replacement rockers (which fit for the most part) and fit them in. if beefy, some steel square tube (3x6 or something) works well. and acts as a rock rail
