MuddFoot Posted March 13, 2014 Share Posted March 13, 2014 ok i changed the fuel injector o rings but now my feed line the goes into the fuel pressure reg leaks where do i get the o ring for it or just fix leak i have the stock o ring but leaks. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 13, 2014 Share Posted March 13, 2014 ok i changed the fuel injector o rings but now my feed line the goes into the fuel pressure reg leaks where do i get the o ring for it or just fix leak i have the stock o ring but leaks. If I'm translating this correctly it sounds like the quick-connector on the fuel rail supply line is leaking? If this is the case, you need this: http://www.jeep4x4center.com/fuel-oil-cooler-line-repair-kit-83502745.html Link to comment Share on other sites More sharing options...
metrictonner Posted March 13, 2014 Share Posted March 13, 2014 I use ordinary o-rings from a hardware store they seem to be fuel impervious. In the old days there was a kit o-ring stuffer but it is not so hard to put the rings in manually. I have had no problem with leaks doing it this way. I'd give you the ring dimensions but I don't remember which ones I ended up using from the boat load I started with but there is a common size that is a perfect fit. Just remember how they came out and check to see that they all came out when you pull out the fuel line. A curved needle pick will help you push and pull the rings into place. Link to comment Share on other sites More sharing options...
MuddFoot Posted March 14, 2014 Author Share Posted March 14, 2014 thank you Link to comment Share on other sites More sharing options...
ParadiseMJ Posted March 14, 2014 Share Posted March 14, 2014 If you're buying O-rings from the hardware/auto parts store you'll need 2 per connector PLUS the little plastic spacer. That's what the connector seal pictured above is...just 2 O-rings and a spacer and the clip*. The center white part is just packaging. The little spacer is necessary ! So if you take the connector apart and DIY, save the spacer. I've never been able to find the spacers anywhere but the junkyard. Then it just goes together like so...o-ring, spacer, o-ring. Total cost = $1 *Edit: I edited this because I forgot about the actual clip. The clip is also available at the parts store in the HELP! section. They come in a pack of 4 or 5 for $3.99. If you go that way buy extra O-rings and do the other fuel connector. Link to comment Share on other sites More sharing options...
