cocy Posted February 25, 2014 Posted February 25, 2014 I have a an ax15 2wd I was going to use but no longer have the truck. It comes with external slave belhouse cross member, drive shaft that should work with dana 35 or 8".
Automan2164 Posted February 25, 2014 Posted February 25, 2014 I would be interested in the parts for the external slave setup, or whole trans if that is required. Keep me posted on if 1987Comanche seals the deal. Rob
neohic Posted February 25, 2014 Posted February 25, 2014 I would be interested in the parts for the external slave setup, or whole trans if that is required. Keep me posted on if 1987Comanche seals the deal. Rob ... and I'd be interested if you seal the deal and need to get rid of the AX15.
Archived
