jackel18 Posted April 23, 2007 Share Posted April 23, 2007 so i put on a new header the other day buttoned everything up and turned her over......fuel leak(from injector closest to fan), no biggie new o-ring. didn't have time to fix it the other day so i jumped on it when i got out of work today. got everything back together, fuel leak.....great(same injector). i took it all apart again, same damn o-ring. as i am putting it all together i can see the fuel rail take a chunk out of the SAME o-ring!!!!WTF!!!! :headpop: anyway, i tried again, same outcome, tossed some tools, cussed alittle, then retreated here for some knowledge. anyone else have this problem or know how to solve it? Thanks Rich Link to comment Share on other sites More sharing options...
reddog Posted April 24, 2007 Share Posted April 24, 2007 grease Link to comment Share on other sites More sharing options...
jackel18 Posted April 24, 2007 Author Share Posted April 24, 2007 i put oil on all the o-rings if thats what you mean, if not should i try to use regular grease? Link to comment Share on other sites More sharing options...
Twisty Posted April 24, 2007 Share Posted April 24, 2007 are you using injector o-rings or generic o-rings? Link to comment Share on other sites More sharing options...
jackel18 Posted April 24, 2007 Author Share Posted April 24, 2007 injector o-rings Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 24, 2007 Share Posted April 24, 2007 check for burrs on the injector, the fuel rail (if that's the side that's leaking), and the intake. if you find any rough surface, clean it (small round file or fine sandpaper), but you'll want to try and vacuum it at the same time if it's on the intake side... check everythin for burrs man, that's all i can think of unless something is out of round and you're now plugging a round peg into a oval hole or something like that... Link to comment Share on other sites More sharing options...
87manche Posted April 24, 2007 Share Posted April 24, 2007 check for burrs on the injector, the fuel rail (if that's the side that's leaking), and the intake. if you find any rough surface, clean it (small round file or fine sandpaper), but you'll want to try and vacuum it at the same time if it's on the intake side... check everythin for burrs man, that's all i can think of unless something is out of round and you're now plugging a round peg into a oval hole or something like that... when filing, use grease to catch the filings and keep them from going into the intake. Link to comment Share on other sites More sharing options...
Mitch Posted April 24, 2007 Share Posted April 24, 2007 I recommend you throw more tools. Link to comment Share on other sites More sharing options...
Duner Posted April 24, 2007 Share Posted April 24, 2007 After you finish throwing tools and cussing, take a deep breath, muster up all of your patience and check the hole for burr's then apply some grease to the o-rings and the holes and carefully work the injectors back into place. I watched my dad the throw tools the first time he worked on my brother's toyota and my sister's chevy. He said he never had any problems on the jag or porsche when he changed injectors but those two little cars pissed fuel everywhere. Link to comment Share on other sites More sharing options...
Oizarod115 Posted April 24, 2007 Share Posted April 24, 2007 you sure its not the electrical connectors? they like to leak fuel once they get old. both mine and my brothers 4.0s did this Link to comment Share on other sites More sharing options...
jackel18 Posted April 24, 2007 Author Share Posted April 24, 2007 you sure its not the electrical connectors? they like to leak fuel once they get old. both mine and my brothers 4.0s did this not to be a fool, but.....how do electrical conectors leak fuel?? Link to comment Share on other sites More sharing options...
87manche Posted April 24, 2007 Share Posted April 24, 2007 you sure its not the electrical connectors? they like to leak fuel once they get old. both mine and my brothers 4.0s did this not to be a fool, but.....how do electrical conectors leak fuel?? he's refering to the renix injectors split body. They like to seperate in the middle, between the electrical connector and the nozzle, and leak fuel from the body of the injector itself. Link to comment Share on other sites More sharing options...
jackel18 Posted April 24, 2007 Author Share Posted April 24, 2007 ok that makes sense Link to comment Share on other sites More sharing options...
Oizarod115 Posted April 24, 2007 Share Posted April 24, 2007 you sure its not the electrical connectors? they like to leak fuel once they get old. both mine and my brothers 4.0s did this not to be a fool, but.....how do electrical conectors leak fuel?? he's refering to the renix injectors split body. They like to seperate in the middle, between the electrical connector and the nozzle, and leak fuel from the body of the injector itself. thanks 87, sorry jackel, didnt even think to specify what i meant. youre sittin there like... MY elec connectors don't spew fuel... this kids a mooooronnn hahah. :roll: sorry bout that :chillin: Link to comment Share on other sites More sharing options...
jackel18 Posted April 24, 2007 Author Share Posted April 24, 2007 you sure its not the electrical connectors? they like to leak fuel once they get old. both mine and my brothers 4.0s did this not to be a fool, but.....how do electrical conectors leak fuel?? he's refering to the renix injectors split body. They like to seperate in the middle, between the electrical connector and the nozzle, and leak fuel from the body of the injector itself. thanks 87, sorry jackel, didnt even think to specify what i meant. youre sittin there like... MY elec connectors don't spew fuel... this kids a mooooronnn hahah. :roll: sorry bout that :chillin: its all good :cheers: Link to comment Share on other sites More sharing options...
fiscus Posted April 26, 2007 Share Posted April 26, 2007 Yes, I've had this happen a couple times too, those sides are real sharp to line up 6 injectors at the same time. Get another set of o-rings & try again, I think it took 3 tries for me (after the 2 or 3 tries with discovering other bad injectors that still leaked...) to get them all seated w/o any leaks. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 26, 2007 Share Posted April 26, 2007 put the injectors in first, then place the fuel rail over them...it will require some skillful positioning on your part, but then you don't have the sharp edge. i did it that way on my 3.8 for the EXACT reason of having sharp edges on the intake Link to comment Share on other sites More sharing options...
87manche Posted April 26, 2007 Share Posted April 26, 2007 put the injectors in first, then place the fuel rail over them...it will require some skillful positioning on your part, but then you don't have the sharp edge. i did it that way on my 3.8 for the EXACT reason of having sharp edges on the intake if using this method, tape the injectors to a plastic ruler or something. Keeps them all aligned so you can adjust them all with one hand. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 26, 2007 Share Posted April 26, 2007 haha, i used a screwdriver to pry them back up...didn't break them but IMO def. not the way to go. the ruler idea is good Link to comment Share on other sites More sharing options...
Oizarod115 Posted April 26, 2007 Share Posted April 26, 2007 ...? i have never experienced trouble doing this did yall vasoline your o-rings on the way in? Link to comment Share on other sites More sharing options...
