Manual Window Regulator Replacement
I replaced the rivets with nuts, bolts and lock washers. One trick I used was to use duct tape on both sides of the window running up off the top so that I had a secure grip on the window as I removed it from the window frame. You will have to remove the front guide bolts and front guide/vent window to make it easier.
