johnj92131 Posted February 17, 2014 Share Posted February 17, 2014 Noticed a large crack in the interior of my glovebox. Started looking at how to remove the glove box and it looks like it is a single piece called the upper instrument panel and runs the full width of the dashboard. Is this correct? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted February 17, 2014 Share Posted February 17, 2014 Glovebox is part of the dash, so yes that piece has to come out, but so does everything else as you have to remove the entire thing Link to comment Share on other sites More sharing options...
SmthnD1ff Posted February 17, 2014 Share Posted February 17, 2014 Stock mj/xj 96- are one molded piece of plastic. Dash has to come out to fix the crack but its not that big of a chore. First remove the dash bezel- two screws above the inst panel, the the rest are just clips. Then the lower dash cover- 4 or 5 screws across the top. Then unplug snd remove your inst cluster- be careful with the speedo cable (I found it helpful to get a set of pliers and a dmall towel to LIGHTLY pinch it and carefully move the cable shaft out) Then remove whatever else is wired up- ac controls, stereo, clock etc Next youll need to remove the defrost cover at the top- a couple screws Under the cover there are three mounting brackets riveted to the dash screwed into the firewall. The windshield makes it difficilt to get to them bur a 3" phillips works great. Last, there are 15mm bolts under the dash behind where the lower cover was- one on each kick panel. I found it easier to just loosen them rather than removing them The dash mounts are slotted and it has to be pulled forward and rotated around the bolts. Once its loose pull it up and over the steering wheel and out the pass door. Not terribly difficult but help to have a second srt of hands. Link to comment Share on other sites More sharing options...
johnj92131 Posted February 17, 2014 Author Share Posted February 17, 2014 Gentlemen, Thank you both for confirming my fears/judgement. SmthnD1ff, thanks for the written instructions! What did you use to repair the cracks? Hot melt glue, JB Weld, other epoxy glue? Link to comment Share on other sites More sharing options...
SmthnD1ff Posted February 17, 2014 Share Posted February 17, 2014 I had to remove mine several times but never had to fix any structural cracks- IMO a decent epoxy should do the trick if its something minor. If its structurally compromised your best bet would be fiberglass. Hope this helps Link to comment Share on other sites More sharing options...
JeepcoMJ Posted February 18, 2014 Share Posted February 18, 2014 Teamcherokee.com has complete new dashes for fairly cheap Link to comment Share on other sites More sharing options...
